  • 2 months later...
Select in your user settings your region and login with an account (that you need to create first). Then the contents will adapt to your region. If your country does not show up, then select the closest one that should probably have near your country.
    • By Bhanu Kumar
    • By Ahmad Baeisa
    • By akhil7j
    • By Puja aingh
      Dear LG Team
    • By OKtay Sa
      Hi there,
      i have an 65oled9flb (webos).
      Any one an idea?
      Greets
      Oktay
