TV firmware popup
I want to ask about my TV. It sometimes show some popup, which before I can read disappears. It has three choices controlled via Green, Yellow and Blue buttons and says something about firmware and deleting channels. I can´t find what that could be. Did you see that sometimes? No updates available on my TV.
Thank you for some help
Hello AWACS,
I'm not sure, but it might help if you put your TV model number and firmware version in your post.
I'm running 04.00.70 firmware on a 49UF850V (if memory serves me correctly) and I get 2 occasional pop-ups, one about the channel list and one about firmware.
If it goes to quickly you can always go into settings and do a check for firmware update.
    • By SHawk
    • By Sqwazy
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By сергей фролов
    • By SailorMoon
