Hybroad Z205 Set-Top Box
Can anybody help me ? How can I add this Set-Top Box to my LG 60UF852V (webos 2.0) with the support by LG Magic Controller (as 1 controller for TV and STB) because Hybroad manufacturer isn't in this huge list of manufacturers in TV. Or can I select other one (similary) ?
8 answers to this question
hello,
I have the same problem. Have you find any manufacturer instead? (who are on the list, cuz Hybroad is still not there)
If yes, please let me know as I would love to use only one remote instead of two :))
Thank you very much
What I needed to do is watch the very first screen when rebooting the set-top box. That was in my case the manufacturer. Everything after that is software from you provider.
Hope it helps.
    • By Mdzh
      I have a LGOLED55CX3LA tv and a TH200 settop box device for IPTV. I'm trying to setup the Universal control function so that I'd be able to control the settop box with my lg magic remote control.
      Unfortunately, I do not see the settop box model under the supported providers. TH200 is a very common model of settop box. How come it's not listed?
      Am i missing something? Is there a way to configure it and control the device using the magic remote?
    • By Sandip Nath
      I have a settop box of Prysm HD. But it cannot be paired with LG Tv remote. If there is any way to do it  please tell me how to do that. The standard product list of settop boxes does not feature the brand that I own.
    • Solution For That Pollution
    • By vivekpohre
      This would be a lovable feature if implemented. Users generally change channels on their settopbox using the magic remote which is very cumbersome.
      So even if someone has done that once why shouldn't the OS cache it and show that list of top 10 most visited channels to choose from.
