Evaluate and clear cache
I have a web app which displays a list of videos (HTML5). App is running for 4hrs straight and then afterwards TV displays the message, "The page you are trying to view is too large. To continue, reload or go to other page..."
Am suspecting that the cache is already full or its memory. Here are my questions:
1. How can I check on the cache contents (eg: in FF and Chrome, I can issue, About:Cache) to know exactly who's consuming the cache
2. How can I clear cache programmatically using C#
Thank you very much.
    • By Ingemar Olsson
      Web OS 4.30. Home screen show history of  APPs video, foto and music above APPs before selected.
      How clear history?
      MENU:General->AI->AI recommendations-> CLEAR USER DATA
      Does not do the job. Only clear Last used APPs.
      Help?
      Regards Ingemar
    • By Alex
      the viewer sits.
      Source:
    • By Steve Bowes-Phipps
      My LG TV works great with terrestrial TV (I have no sound bar) but when I stream content from, say NowTV, iPlayer, etc, particularly films, the background sounds and music are louder than the speech, making the viewing experience quite frustrating.
      Is there something I can do to improve this?  I am already on Clear Speech in the settings.  I don't mind if it's a sound bar or audio streamer I need to get, but I want to know why it only affects streamed content and what I can do about it?
      Many thanks in advance for your help forumites!
      Steve
    • By Raato
      How can I clear the LG TV (UM7600PLB / os. 05.10.25) cache?
      I don't mean any particular app or browser but the whole TV cache. The cache contains incorrect data.
      The data is cached because the factory settings do not help. I know you have to have the kind of script that does it.
    • By RLR
