By Cody94549
By jcol5786
A few years ago I bought a 43" LG Model 43UK6200PUA, manufactured in 2018. I'm from Canada but I purchased this TV in the US. It was a store demo unit on for a great price. I took it home to Canada, set the location to Canada and setup up in our bedroom. It has been working fine with our Fiber TV service as well as Netflix, Amazon etc. We also to have a 60" LG TV in the living room which was purchased in Canada. This TV is similar in age to the one in the bedroom. Recently I started watching the LG channels on the living room TV. I hadn't really paid much attention to them before but now I enjoy them. My problem is that the LG channels do not work on the bedroom TV. I suspect because it was purchased in the US but located in Canada. With the location set to Canada the LG channel guide populates and shows what's on however when I select a program I get the following message.
By Low Grade
many thanks in advance😃
By Magsing
By Itachi3431
Hi all,
P.S., running latest Web OS
- 4 replies
- 3,797 views
- 0 replies
- 2,039 views
- 2,489 views
- 1 answer
- 11,623 views
Henri-Pierre Leveillard
Is there a way to add new countries under general/location/ ? I only have australia, india, indonesia, myanmar, NZ, Philippines, Singapore, Sri Lanka, Thailand and vietnam.
I am looking for apps able to stream tv channels and particularly sports soccer live channel. Can anyone help?
43LF630T-TA
