By Nicola123
By svsrama
Sriram.
By cptl
Any thoughts?
By Sandtonman
Dolby Vision is 22.11.
By Edgar Corona
I have a 55" smartv, i'm having problems with Netflix app, anyone knows why, i can't open de app, everything after and update send it by the tv..
tulu
Hello all,
I have just bought an LG 49UF7787 from Germany. After setting it up, the preinstalled Netflix app wanted me to update itself. It does not work without updating. When I try to update, it gives me "content not available" error. It is not even listed in the all apps section.
Is it something related to the TV itself or a general Netflix app problem on WebOS 2.0?
TU
5 answers to this question
