LG satellite list problem on restore channel backup. 42LB670V
Hello.
Im in setting backup my channel list. I restore my channel list is wrong. Restores only the TV list but not the Satellite list. Also delete a transponder satellite list Thor. Whats wrong?  I must also restore the default settings. Tv is LG 42LB670V. Firmware lastet 5.00.55
    • By OhmorrowSouthWales
    • By Michael Hirons
    • By Tony Levy
    • By BozaB
      I need help, I bought LG Oled 65 C41 LA tv two days ago, tv is working mostly fine, except when I watch LG installed streaming platforms ( Netflix and MAX tested ) tv freezes and after about 10 seconds it restarts. It does not have any pattern as far as I know, sometimes I can watch 20 mins, last two times after six minutes it crashed and restarted automatically. Can someone please help me, how can I resolve this issue? Did someone had sam problems already? Is my tv broken or I can do something to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
