Why LG 43UF680T UHD doesn't have TRUMOTION? PH
By ato53
I have a new C4 TV.
Thanks for the follow-up
By coltaz
By Magsing
By Satya_
Software version 05.30.10 default web browser just updated and the address bar appear on the top of the screen which bother me a lot while playing a video please add a Full screen option to it
By Xuancong Wang
Dear LG TV developers,
I am glad to see that LG Smart TV has a built-in web browser and LG API supports "openBrowserAt" so that my smart home controller can open a web page on the TV. However, nowadays, we also have ms-teams online meeting that is accessible through web browser which the LG TV supports. However, this requires the browser to have a microphone to record audio and to have a webcam for video recording. Also, certain smart-home systems also need built-in microphone to record voice commands so that no additional standalone unit is required next to the TV.
Unfortunately, LG Smart TV (I have OLED48A1PTA) does not have microphone neither does it support USB mic/webcam. So I am writing this post to suggest that future middle/higher-end LG Smart TV can be equipped with these. Moreover, it might be possible for TV firmware update to add the support of USB webcam/microphone so that they can be used in web browsers for web-based online meeting.
Thank you very much for your consideration!
Best regards,
Xuancong
edzyan014
Guys!
Please help im having a problem with my TV 43UF680T my country(PH)
the LG support/technical said that this model doesn't have a TRUMOTION feature here in our country
is that possible? even they have same in specs and hardware?
i don't get it is it because of the software i need to update?
I'm thinking update via manual using the SW of other country will resolve my problem.
please guys i need your expertise and your idea about this?
For reference:
here's the latest SW in my country (PH):
LINK: (
latest SW release in (AU)
LINK: ()" Software File (Version 04.20.65)"
thanks!
