Reset to initial settings
By Cody94549
By Low Grade
many thanks in advance😃
By Magsing
By Itachi3431
Hi all,
P.S., running latest Web OS
Bryan Prejean
Anyone else have a problem with their 60UF7300 not locating any wifi gateways? I have to keep resetting the tv as new to get the tv to see ANY wifi gateway. Lg sent a repair guy here and replaced the wifi antenna but I'm still having the same issue.
