search hd
By Mohammad1403
Hello there,
Is it possible to turn off search on the home screen, or filter results to show only apps? Ideally, I'd like to limit content to be appropriate for kids.
By Raffi
searching a specific channel from a long list would be easier if a search box is added that will list available channels as you type
sorting channels alphabetically doesn't do what it says.
Regards.
By kingfelix
When you run a search, there is a "web" button that lets you view results on the web. This opens a mini web browser which defaults to having explicit results shown. This make is too easy -- even for a child -- to accidentally or purposefully have the TV screen filled with sexually explicit content.
There needs to be a way to disable or control with a PIN the ability to see search results on the web.
OR
the browser that launches the web results needs to be defaulted to HIDING explicit results
By Mohammed Ghareeb
Can any one give me a method to search about a specific channel in LG smart tv. It is the most stupid tv app.
By Roman Dreyer
When I search something in WebOS, I get various types of results. For example Youtube results, DLNA results, Netflix, web search with what I searched and so on.
All that, except for Spotify result. why?
For example: if I search for David Guetta, I'll get suggestions for Youtube clips, but no suggestions for Spotify.
Could you please integrate Spotify in the search results?
For now, I had to move to Chromecast with Google TV, because there, not only I can search, I can command Google Assist to actually play something. Meaning that with one voice command, I can tell it "play david guetta on spotify" and that's it, it plays.
I don't expect the assistant enhancements like PLAY command, but please, show results from Spotify too.
Thank you.
