HBO Go movies restart
I have a LG Smart TV 32LF650V.
When I play movies on HBO Go, they play fine about an hour and a half. But if the movie is longer, it randomly stops, then starts from the beginning. So I must go fast forward. But it happens again after a few minutes. It becomes a pain.
speedtest.net shows 58 Mbps, so the speed is not an issue.
Any ideas?
Thank you.
    • By ironmonkey
      Just bought an LGLED-65UJ630 65INCH TV. Right away I started to get the message "This app will now restart to free up more memory". After searching the internet and forums, I now understand that this problem is huge, it has been going on for years now and it is right across many models of LG TV's.
      I have tried everything to fix this problem. It has the latest firmware. I did the factory reset and that lasted 4 hours before I got the message back. I turn off the TV and leave it for 10 minutes, maybe one hour later I get the message. I delete browsing history, maybe 10 minutes and I get the message..... you get the message.
      As I understand it, the problem is that LG TV's don't have enough internal memory, but they have shipped a ton of their "smart" TV's with this problem.
      My question is, has anybody heard anything from anybody, anywhere about a solution to this problem. I really want to keep this TV, but it is not fit for purpose in this state.
    • By Puja aingh
      Dear LG TEAM
        Kindly resolve this issue
      My lG TV MODEL NO IS 32LK628BPTF
    • By Maria D
      How to change view from 16:9 in movies to fit full screen
      LG QLED B22
    • By Velvet_Noir
      Hi, I have the option to right click and pick the subtitles on my Mac when watching movies in the VLC Player, but I can’t do this on the LG OLED, though. I already renamed the subtitle file to be the exact same as the video file and I did have the SRT file in the same folder where the movie is. However, when I connect the hard drive to the TV, the subtitle still doesn't appear. The format of my hardrive is NTFS. Can anyone please offer some advice?
