Smart Share Videos Duplicated
By Will M
By Lesbo
By Rex G
almara
I recently bought LG 43UF778V and so far it has been great. However when I stream videos from my PC using smart share each of the videos appears more than once. Additionally some of the duplicates have had their names changed to something which bears no relation to anything stored on the PC. Does anyone have any explanation for this weird behaviour and/or a solution to correct it?
