- 1
Annoying Ads on YouTube
By Lee Magee
By Владимир Морозов
By u84six
By JonoW
By Stephen Pritchard
For some reason the scroll right and left arrows have disappeared from the youtube app when using my mouse.
I've tried installing the app again but no luck.
Any ideas?
archs
Hi!
I'm having this annoying Tullamore ad in YouTube that hasn't been replaced for last week. It's driving me crazy 'cause it's played almost before every youtube video I choose by remote controller.
Is there any way to block those ads in router level? or any other way?
Or at least can I have various ads in webos YouTube?
archs
