LG 65uf6800 dont see how to get apps
I am able to sign into account management and used my facebook to sign in, but I dont see any options anywhere on how to get to the LG store to get apps. I dont have the remote for the TV but I have another LG remote that seems to work with it, can anyone help me?
    • By thewookiewon
    • By Pranay Mokida
    • By MNHL
    • By Tobin
      Tobin
    • By Luka Pantsulaia
