LG 55UF685V(-ZB FW: 04.20.70) - Magic Remote AN-MR600 not working
By Roy Brown
By RJ Fischer
By Rex G
By u84six
- 3 replies
- 1,515 views
- 695 views
- 1 answer
- 764 views
- 0 replies
- 654 views
ragerino
I saw this TV for €749. Since someone answered on amazon.de that the Magic Remmote will work I decided to grab this TV.
Now my Magic Remote arrived and I have problems registering it with the TV. When I press the wheel-button I get te message "Failed to register Magic Remote. Please try again".
I already tried changing the location from Austria to Germany (as described in another thread here), hoping to get a firmware update to resolve this problem.
Would be great if anyone could help me to make it work!
