Hello
I bought a new TV LG 55UF850T, the problem is : there is NO TruMotion Option in TV Settings !!
my friend bought one also before 5 months and I checked his TV and I found TruMotion option !
I'm running on firmware 04.00.55
Any help ?
Thx
Hi Zuhair, I have the same model and have noticed the very same issue: No TruMotion settings. I am very disappointed that this was was seemingly removed from the firmware by LG.
Do you know which version firmware your friend has on his TV? Maybe we could manually downgrade or something to get the TruMotion option back?
Also, on an unrelated note... Have you been able to find the proper picture settings? I noticed that if I use the settings which they suggest on the AVForums review for the 65UF850T, I get a slightly reddish hue.
Please let me know if you manage to solve either of these conundrums with this TV. It's good for the most part, just these small things that need to be sorted out and then I'd be soooo happy.
Hello
I checked my friend model its 55UB NOT 55UF. UF is better. I went to LG to check other TV because I thought just my TV has the problem, but It's not. Also the store TV has the same problem !! I checked the 49,55 there is NO TruMotion. There is TruMotion in 65 only. I told LG service I don't want this TV anymore. And they contact the manager to checl this problem and they still confused about the problem.
I'm still looking for solution.
    • By PVD
    • By hollean
    • By AJO
    • By BozaB
      I need help, I bought LG Oled 65 C41 LA tv two days ago, tv is working mostly fine, except when I watch LG installed streaming platforms ( Netflix and MAX tested ) tv freezes and after about 10 seconds it restarts. It does not have any pattern as far as I know, sometimes I can watch 20 mins, last two times after six minutes it crashed and restarted automatically. Can someone please help me, how can I resolve this issue? Did someone had sam problems already? Is my tv broken or I can do something to fix it?
    • By DeJaVu
