Lg tv broken any advice
So had my tv for a couple years or so now and had no problems until now just wondered if anyone might know what could be wrong with it and if it is something that could be repaired it was fine last night until it just cut off, turned it back on and now all it does is flickers on and off about every 3 seconds with a really dim picture any ideas what it could be?
    • By netsplit
    • By Guy Mawson
      I can’t use my remote with the new update. 17. Something I think?
      OK my 55” is a few years old but it was working fine until an automatic update on an unsupported TV! I mean, why update unsupported tv’s with untested software?
      Planned obsolescence - making us upgrade? Well, it’s the last LG telly I will buy for sure
    • By Bob17821
      The Wi-Fi module in my LG TV, roughly 5 or six years old, (WebOS UJ6300) is apparently broken.  I am looking for a solution cheaper and maybe more interesting than having the TV repaired.  There are devices which will pick up Wi-Fi, convert it to ethernet, and deliver it to the male  part of an ethernet port.  In the past I have used such a device to provide Wi-Fi support to a desktop computer which did not have Wi-Fi support but did have an ethernet port.  I forget the particulars, but it did work just fine. But a smart TV with Web 0S is not a desktop or laptop computer.  My concern is how to provide the SSID and password to the device.  My vague recollection is that such a device in a laptop or desktop computer can trigger a dialogue which requests the SSID and password.  But will web OS provide such a dialogue?  If I recall correctly, wired ethernet connections do not require SSIDs or passwords.
      Thanks,  Bob
    • By Gecko64
      Hello, the wifi of my smart TV is broken since the last update.
      The remote control from my phone too when i use an opérational ethernet connection.
      Tried :
      Full setting reset
      Reboot
      Power reset
      Observed :
      After the power reset and unplugged during at least 10 min, the WiFi networks was at new listed but impossible to connect, it says WiFi network not found.
      After a new power off, the searching of wifi networks didn't end without result.
      The remote control also lag a lot each 10 seconds and during 3 or 4 seconds.
      TV Informations :
      Model : 49SJ800V-ZB
      Devide Name : [LG] webOS TV SJ800V
      Serial Number : 711MAVDM8903
      webOS TV Version : 3.9.0-62709 (dreadlocks2-dudhwa)
      MAC  Wired : 38:8C:50:F3:2B:5D
      MAC Wireless : 7C:1C:4E:A0:E8:C7
      ESN : LGTV20171=11002626448
      VSN : 5DBF066A
      Widevine : LGTV17CLGE005126094
      Question :
      Is there a way to downgrade by putting the firmware on a USB Key with a FAT 32 filesystem on to be sure it could be read by the TV ?
      Thank you in advance for your help.
    • By grabber5.0
      Tried to launch the Amazon Music app on my TV this morning and got this error. This just looks like an expired certificate error, but the app is 1.0.0 and hasn't been updated since release in 2020, so I suspect it's not supported anymore anyway. Anyone have it working on perhaps a newer TV? This one's two or three years old.
      Sent from my Pixel 5 using Tapatalk
