Can Chinese lg smart tv flash foreign firmwares?
By Will M
By mycop
Greetings.
By Lesbo
Cute002
I don't want to use Chinese firmware,can I flash hk or Taiwan firmware,my TV is 4k HDR(55LG61CH-CD)
