I would like to buy a smart TV that is capable of playing from my large collection of ripped dvds I've collected over the years.
Does webOS 3.0 support connecting to windows homegroup?
If not does it support any 10 media sharing services?
What file formats can it play?
    • By wallyricks
    • By Marko00
      only with cancel button.
      How to fix it?
    • By bogeyman62
      Has anyone been able to run Screen Share from a Windows 10 PC? Mine will not connect to the LG TV.
    • By GMosley
      I have three LG Smart TVs in my home. I have a Windows 11 PC with videos on the hard drive. It seems like I should be able to connect to the PC videos from any one of the TVs. When I "show all inputs" on the TV, the PC shows up. When I select it, I get the message "Device not connected". All devices are connected to the home wifi network. I also have LG's SmartShare running on the PC and the video folder has been selected for sharing.
      Any suggestions?
      Thanks.
    • By JeanF
      Is-it possible to have another navigator like Firefox in addition to WebOS ? How ?
