I have recently purchased LG 32LH602D TV which has WebOS3 Version 03.20.08. I usually stream Pictures/ Audio/Video from my WD NAS drive. Previously i had Samsung Smart TV and streaming has never been any issue. Now setup is same only change is Samsung has been replaced by LG TV and I am facing issue streaming, Pictures take lot of time to buffer/ videos take time initially to buffer and then again stop in between to buffer. Spoke to some local LG technicians without any help. Is there any know issue. I do see lot of lag even while changing menus like settings on TV.
I am using LG Photo & Video app to stream, been reading Plex availability in LG store but I don’t find it there,… is it available or removed?
My setup is .
NAS connected to router via LAN cable / TV connected to same router via LAN cable ( tested Wifi as well but same issue)
My all other devices can stream from same NAS device without any issue Wifi or LAN
You can post now and register later.
If you have an account, sign in now to post with your account.
showkatl
My setup is .
Any help will be appreciated.
Cheers
Showkat
