LG webos3 - HDMI/ARC
By Freudstein
I recently bought a 55UJ6309 TV with one a must to have requirements is the multiscreen feature.
I thought that Webos 3.5 was supporting it but I discovered unfortunately that it was not !!
I would like to know whether this feature is under development and will be updated in the nearest future or not ?
Thank you in advance
By Freudstein
By Jasim Peringattuthodi
I am an AV expert but new to LG smart TV,
Recently i purchased a LG 43UH651V smart TV with WebOs3 , i looked in to the specs and it was amazing
The TV also performing very well. I have a technical question that any Web OS expert here may can answer my question
I tuned my satellite channels (DVBS2) on this TV ( Intelsat 17C 66E)
Sadly, this satellite is not listed in the preset satellite lists.
I am using an universal LNB to cover both polarities which has a LNB frequency of 5750-5150
But unfortunately the satellite frequency setting of my TV doesn't have this frequency range. i tried to setup it manually, but its not supporting the universal frequencies.
I can use 5150 frequency, but its covering only one polarity. and limited TP range frequency also
I am attaching 2 images here (one from my existing satellite receiver which is worked fine form me and the other one from LG TV settings
So if any one can help in this regard will be much appreciated
Many thanks in advance
Jasim from Dubai - UAE
By omgold
I just got a new TV with WebOS 3 and I would like to mention one thing that really annoys me about it. It is the reaction of the interface to key presses on the remote control. On my previous TV with WebOS 2, responsiveness wan't exactly great either, but on the new one it is so bad that I consider returning it.
It drops key presses so often that navigating apps isn't fun at all. It feels like the OS considers a key press more like a friendly suggestion to do something instead of a command. Anyone else notices this also? Can it be fixed?
Macek555
What am I doing wrong on LG TV 2016, that whenever I turn TV on,
my Bluray (connected trough HDMI/ARC port) iz swicthed powerde on autoamticaly also,
and sound is starting imidietly to sound from Bluray, not from TV speakers ?
I want to sound trough speakers only when I chooes (change output
from "TV internal" to "TV output (HDMI/ARC)", like I had in old Samsung TV.
Tried to connect BR and LG TV trough optical link, but it doesnt work at al. It works
only trough HDMI/ARC.
