webOS_3.0 Recordings (Schedule)
am I missing something, or is there really no posibility to:
- change only TV station of a scheduled recording. I can change, begining, end of recording, occurancy, but not a TV station program
- cant see end of recording in scheduled list (just begining)
- if I mistakenly create (on 1 tuner TV) another scheduled recording, and there is already some sheduled event insame time frame, I cant just simply change 1st or 2nd recording, but only abandon this new 2nd recording, or delete 1st one.
Any help or hint ?
    • By Chris Jones
      My TV is driving me nuts!
      I keep getting reminders for programs starting for programs I don’t watch or have never watched and 2. The tv even switches on for scheduled programs that I haven’t set.. actually I have only ever set one program reminder and that has now been deleted.
      I can’t see any programs in the reminder page or anywhere in the tv programmer?
      Short of resetting the tv I don’t know what else to try? And I don’t really want to do that until I know how the tv ended up like this? Plus I don’t want to have to reload and sign in to all my apps 😬
    • By JohnoFon
      I am using an LM6300PLA, WebOS version 05.30.11
      When I try to record a series from the Live TV - using input the satellite connection - the first episode records correctly, but subsequent episodes all stop after 3 minutes.
      What am I doing wrong?
      Further annoyances are that I can't just set it to record all episodes of a particular show (the way my HUMAX Freesat does), but only 'repeat recording on specified days' with no end-date.
      Does this mean that the recorder has no access to the Electronic Programme Guide, but just sets a time and duration? If the broadcaster reschedules the programme does the recorder just pick up the replacement?
    • By Fritz Heckert
      I bought a new LG Smart TV Type: 43UQ75009LF.AEUD with webOS 22.
      I previously had the type: 43UH620V with webOS 4
      The problem is that I have a lot of recordings from the old LG TV on my hard drive, all from non-encrypted, open channels such as ARD and ZDF Germany, which I can no longer play on the new LG TV because the data is encrypted .
      Is there a solution to make these files (STR), I copied the whole "LG Smart TV" folder including the "lg_dvr" subfolders and the "TN" folder to my iMac, to make it viewable again?
      I know that the .STR files contain the video. Is there a solution under macOS or Windows10(11) to decrypt this data and make it viewable?
      I couldn't find anything with a Google search.
      Thanks for tips on this.
    • By mark3433
      I set a schedule on my 55UK6750PLD to record several hours of satellite TV every day.
      The problem is that this recording schedule regularly disappears and so needs setting up again and again, several times a week.
      A couple of years ago this worked for months without fail so I suspect a bug has been introduced in a more recent version of firmware as automatic updates are enabled.
      Current WebOS version: 05.40.26
    • By escalinci
      Hello all,
      I'm recording DVB-T2 broadcasts in germany, and most broadcasters offer multiple audio tracks, between 2 to 4, in HE-AAC. When setting a recording plan, there is no option to choose an audio track. After recording, there is an option to choose audio tracks, but only the first track has been retained. Is this an unavoidable limitation, or can the multiple tracks be retained?
      Complicating matters is that often, multiple tracks are marked as German, so for instance with a dubbed program where the original sound is also broadcast, the original sound is often named as "German-2".
      Cheers!
