Hi folks,
I'm currently trying to help my mother set up her new LG WebOS LF590V.
Everything seems to be fine apart from the following:
- the channels are not ordered in any useful way (although I can manually change that)
- and the 'guide' menu shows channel names but generally does not provide any programme listings. No error message either.
I can't find anything useful online.
Any ideas guys? My mother spent quite a bit on this TV and is very concerned.
It is connected to the internet and had updated software.
Thanks in advance.
  • 2 weeks later...
    • By northshields
    • By Peter_T
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By RussS
      Russell
