Lg Store isnt available
  • 1
I got my 65UH8500 and loaded one app.... after that no way to update anything... any ideas... TV keeps on displaying all king of messages...  "content not available", "unable to establish SSL..." obviously my internet is up an running very well... any ideas how can I get apps loaded?
    • By Bhanu Kumar
    • By Ahmad Baeisa
    • By akhil7j
    • By Puja aingh
      Dear LG Team
    • By OKtay Sa
      Hi there,
      i have an 65oled9flb (webos).
      Any one an idea?
      Greets
      Oktay
