Hello everyone
My parents just bought a "TV 55UH668V" that runs webos and I download a movie 4K MKV file
The TV can not find the hard disk, is this normal?
Sorry for my english , i'm french
Loïc
  • 2 weeks later...
  • 3 months later...
    • By Lorenz
    • By MinoDc
      Hi to all.
      What do you think
    • By odesanmi kolade
      I have been trying to downloading Aptoide TV on my LG smart Tv but keep showing File downloading not supported.. My goal is how I can get zoom conference app running on my Smart Tv. Please help!!!
    • By Darshan Giri
      I was unable to install the remote control app(on TV) after bundling with Sandstorm webdriver code. Getting below error. ares-install ERR! [com.webos.appInstallService failure]: luna-send command failed <update manifest file failed>
