Can I extract/copy/share TV recordings from internal memory?
I own a LG 42LB6500 which has an internal HDD and allows to record from live TV.
Since it doesn't recognize any external HDD I've tried (too bad I realized that didn't work before the guarantee expired) I've been recording from TV into the internal memory and I have some videos I would like to keep.
Is there a way to copy those recordings into an SD card or a USB stick, so I can store them somewhere else and play them on different devices?
Thanks.
    • By Batman
    • By andystaffs
      Just bought a new LG 43UT91006LA TV .
      After one week we're getting a "short of memory " screen warning before TV shuts off and restarts . I've not loaded any apps but I've managed now to delete one . I've checked that the apps are updated . I'm thinking that I can rid myself if the games but not sure how to do this ..I'm a bit baffled that a one week old TV can't cope with it's pre- installed apps ?!
    • By JohnoFon
    • By ironmonkey
      Just bought an LGLED-65UJ630 65INCH TV. Right away I started to get the message "This app will now restart to free up more memory". After searching the internet and forums, I now understand that this problem is huge, it has been going on for years now and it is right across many models of LG TV's.
      I have tried everything to fix this problem. It has the latest firmware. I did the factory reset and that lasted 4 hours before I got the message back. I turn off the TV and leave it for 10 minutes, maybe one hour later I get the message. I delete browsing history, maybe 10 minutes and I get the message..... you get the message.
      As I understand it, the problem is that LG TV's don't have enough internal memory, but they have shipped a ton of their "smart" TV's with this problem.
      My question is, has anybody heard anything from anybody, anywhere about a solution to this problem. I really want to keep this TV, but it is not fit for purpose in this state.
