Can connect my TV to my wireless no problem but when i use an ethernet connection via a powerline adaptor i get no DNS access.  It sees my home network but cannot get out onto the Internet.  Any suggestions even used 8.8.8.8 for the google DNS.
    • By crct
    • By akhil7j
    • By forum1
      My LG 49UB850V LED TV  browser is too old. The most of the pages not work any more. How to easy update just one simple browser app? For example, often browser show error during open new page. It show certificate expire problem and page not load at all.
      This mean LG sell product without update at least browser certificate and now we are stuck and can not even load one page from WWW.
      Shame on you LG. I will not buy any more from you.  How dificolt is to release new update to update OS certificates? Microsoft Windows did this, android did also for old phones, etc... Really, can not undestend this asian people from Korea.
    • By Trung Hiếu Trần
      Specs: LG OLED 55C3
      Router speed: 250mbps
      System: webOS 2.3
      Any ideas on how to fix it?
    • By makem
      I have a  LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
