LG 52LF590 - To many devices on Windows 10. How i can fix this ????
I have this problems on my Home......... i have a PC (192.168.1.2) and a LG WebOS (upgrade to latest firmware) connected to same router whit a fixed ip to same Network.
The problems it's every time i turn on my PC if my PC it's turned also (on the other rooms) on windows 10 i see a newest and every time differs devices has been added!!! After one or two weeks the number of same devices every time i turn on my TV it's be reach 100 and i need to deleted manually one at one every time.
How i can remove this ?? I see all this devices as PNP devices............ i don't understand because everytime i turn on my TV a newest devices it's be added on windows 10. My TV has a fixed ip address over my LAN also same my pc.................... how i can fix this trouble ?
    • By David Joseph
    • By The Old Man
      Hey LG
      Yes I am NOT happy
    • By wallyricks
    • By Marko00
      only with cancel button.
      How to fix it?
    • By BGee
      On my LG 60SJ850T, Watching Horizon from AppleTV streaming service. Western with some scenes with Apache language being spoken. No subtitles appearing. When CC is on, see “foreign language being spoken”. When viewed on iPhone, there are subtitles. Have tried same movie using chrome cast TV, and casting from iPhone to Apple TV device. Never get subtitles. Verified subtitles work when I stream to same chromecast TV connected to a different TV.
      reset LG TV to factory settings after trying all available CC and subtitle settings on TV. Still no subtitles.
