  • 1
New firmware 04.05.25
4 answers to this question
From LG web site :
[04.05.25]
1.Apply the EPA specification.
- Notify ?the energy consumption may be affected? message if picture mode is changed and ABC/MEC is changed.(APS<-> Other picture mode)
2. Change the Picture Quality setting.
From LG web site :
[04.05.25]
Thanks. Is there an official URL where they put release notes?
    • By SHawk
    • By Sqwazy
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By сергей фролов
    • By SailorMoon
