Replace Default Pictures with my own
I've had my new LG TV for over a month now and I really don't want to see that Golden Retriever sample photo anymore.  I'm sure he's a great dog and all but...
How do I delete and then replace with my own photos so if no input is found it will show my own photos?
None of the solutions I've found work.  This should be much easier.
Any assistance would be greatly appreciated.
6 answers to this question
    • By robsie
      Hi, TPTVencore worked before software upgrade 05.40.61, program loads no issue when play is selected error message appears saying refresh is there a work round for this
       Talking pictures TV have no resolution for the issue,
      TV is a SM8600PLA tv is hard wired with a strong internet conection
      robsie.
    • By woof
      I have a couple of LG OLEDs in shared spaces, with external speakers, one via optical and the other via analog jack (confusingly named headphones). Whenever bluetooth headphones are used and then disconnected, the TV reverts to "internal" terrible audio. For non-technical people this is permanent. Do I have to train everyone to select the device from the long list or can I set a default?
    • By starwoodtech
    • By starwoodtech
      I followed the instructions to set the default input on my TV, but every time I cold start it, it simply goes to the screen where there is a list of apps. I try to repeatedly go to the HOME app to try to set it again, even though it already shows HDMI 4 as the start up input, but it simpy goes to the default screen where my apps are listed.
      Does anyone know what it would take to set this?
    • By Ozzie T
      We have a 65UM7300AUE with software version 05.40.10. We have a Google TV dongle plugged into the HDMI 1 port and that is the input we use most of the time. Until recently every time we would turn the TV on it would default to HDMI 1 and the Google TV home screen would be the first thing we’d see. Life was good. Several weeks ago that changed and now the LG OS (I assume) home screen is the first thing we see. Then we have to use the LG remote to select HDMI 1 each time. We never used to have to do this or use the LG remote at all. Kind of annoying. We think we have HDMI 1 chosen as our default input but it doesn’t seem to matter. Any ideas on how we get things back to the way they used to be with the TV defaulting to HDMI 1 automatically?
