DVB S2 & T2 should seprately listed in inputs menu
By Horniak
By DW1
By pingber
All of a sudden, the row of inputs showed up at the bottom of the home screen on my C1. I’ve tried every setting but can’t seem to get rid of them. I used to just call them up as needed (input button on remote) but now they’re there permanently. Any ideas?
By JaGatorEd
I purchased MR23GN and while most of the functions seem to work ok, the message of "Remote not supported by this TV" keeps popping up.
By denisuu
Hi all,
I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4. I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
pedy6990
I use both of dvb-s2 and dvb-t2 tuners. It's realy complicate and difficult switch between them.
I find it after couple weeks (a button as name as filter on top of channels list).
My suggestion is put a live tv input for each tuner
It will be really easier to access from smart home and inputs menue.
Also it will be able to watch channels from both tuner in multi-view.
3 answers to this question
