LG 43UH610V Bluetooth?
I am trying to connect Bluetooth headphones to the 43UH610V but can't find how to (or even if it has Bluetooth...)
The WebOS manual says it is available through SOUND > SOUND OUT but I can only see a 'Wired Headphones' option.
I'm suspecting that LG cut costs and did not include Bluetooth with this model? Strange as I'm sure a Bluetooth module costs pennies these days to include!
    • By JamesH
    • By Fredrik Andersson
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By Kane Murphy
    • By janisad
      I have an LG 32LJ610V TV.
