By mycop
Greetings.
By denisuu
Hi all,
I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4. I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
By StanJ
I've seen an older thread on this topic but it doesn't look like anyone found a solution to disabling the screen saver, so I'll try a new one.
On virtually all my LG TV's (I have three OLED's and two LCD), the screen saver interferes with my music app (like Plex, Spotify or Amazon Music). I mainly use Plex for playback of my music which is stored on a central server (NAS) and from the app loaded on a Fire TV stick or cube. After about 20-30 minutes, the album art and other related music information (lyrics, song title, duration, etc) all goes black. If I run Plex (or Spotify) directly on the LG TV via the LG Content store app, the screen saver with fireworks always comes on in about 2 minutes.
I've tried all the different methods to disable the screen saver function including turning off the Timers, Auto Power Off, HDD Storage, etc. I also tried opening the hidden menus by pressing the mute button 5 times but that menu didn't have anything relevant.
Interesting is that the screen saver doesn't come on when using Spotify on a Fire TV stick or if I playback music through a USB device. But i don't use those methods often, mainly Plex to access my music server where I have about 500 CD's stored in ALAC format.
Has anyone found a way to disable the screen saver function? I know the logic for having it (to prevent OLED burn in) but I'm not leaving the same image on for more than the song duration (about 3-5 minutes). It's annoying to check the screen for the a music title or see who is on only to find a black screen looking back. Thanks for any help.
By duckie133
VERY ANNOYING!!!!!!!!!!
By curious george
Hi, I'd like to disable the bluetooth on my G2 and was wondering if this was possible without having to disconnect the bluetooth module in the back?
- 1,616 views
- 2,259 views
- 2 replies
- 3,813 views
- 14 answers
- 30,906 views
ConkSMASH
So I have a handicapped brother who plays with this tv all day. He is very good with getting into things to the point where I, a fairly tech savvy guy, will scratch my head saying "how the hell did he do that?"
When using this tv, he uses the remote from our cable box (Optimum/Samsung) which only controls the power and volume on the tv. But leave it to him to find something to toy with. He found that when the mute button is repeatedly pressed (something he regularly does), this menu pops up. (Pictured below) I don't even know how to access this menu with the factory remote.
I figured maybe it was a software glitch, and maybe it would get corrected over time with a software update. So I updated it the other day from 04.00.30 to 04.05.25, but no such luck. I was wondering if anyone had any ideas about if there's a way to disable it. I'm new here so I'm not sure if there's someone in particular I should direct this to that might be really great with the OS and can help.
