Tom Dobridge Posted November 25, 2016 Posted November 25, 2016 Can I stream my Amazon Prime Music Playlists on LG Web OS? Quote
1 Andrew Bywater Posted January 11, 2017 Posted January 11, 2017 also wondering the same - any solution? I imagine only some sort of screen share option from phone/tablet/pc since I don't see an app for it? Quote
1 dqbarber Posted November 19, 2017 Posted November 19, 2017 Same. I (and you probably do too) have nice speakers hooked to my entertainment system. Prime music would be a great feature Quote
0 Elliott Rodgers Posted September 24, 2018 Posted September 24, 2018 I was hoping to stream Amazon Music too. I can do it with Fire Stick Quote
0 bill456 Posted September 26, 2018 Posted September 26, 2018 Yes you can play Amazon Music to your LG smart tv through connecting any external source connected via HDMI, ethernet, component, etc or stream via bluetooth (if supported), smartshare, Miracast, etc. I listen streaming from my mobile phone Quote
0 Elliott Rodgers Posted September 27, 2018 Posted September 27, 2018 On 9/26/2018 at 9:35 PM, bill456 said: Thanks Thamk you for suggestions. Elliott On 9/26/2018 at 9:35 PM, bill456 said: Yes you can play Amazon Music to your LG smar7t tv through connecting any external source connected via HDMI, ethernet, component, etc or stream via bluetooth (if supported), smartshare, Miracast, etc. I listen streaming from my mobile phone Quote
0 dqbarber Posted September 27, 2018 Posted September 27, 2018 it would be a perfect software upgrade. 1 Quote
0 George Hofmeister Posted September 28, 2018 Posted September 28, 2018 I did contact Amazon asking them if they were planning on a dedicated app but the answer was negative, which is disappointing as they have managed to create one for Video. More nagging needed. Quote
0 fillysun Posted March 15, 2021 Posted March 15, 2021 Maybe you can try to use the tool link hidden, please login to view to help you. As Amazon Prime Music files is protected that can't be used on other devices directly. So, this tool is here to convert and to your device first. Then you can move Amazon Prime Music tracks to the platforms you like for playing. Quote
0 Nikky Posted July 1, 2021 Posted July 1, 2021 Before waiting for the upgrade version of Amazon Music, you can try to link hidden, please login to view with the help of third-party tools like Tunelf, and then move the downloaded music tracks to an USB for streaming on your TV. Though it's an available way, be aware that such downloaders will charge you some money. Quote
0 Freya Gong Posted July 22, 2021 Posted July 22, 2021 Same question as you. I hope to stream Amazon Music too! Quote
Tom Dobridge
10 answers to this question
