Settings keep resetting
By Cody94549
By Low Grade
many thanks in advance😃
By Magsing
By Itachi3431
Hi all,
P.S., running latest Web OS
By cptl
Any thoughts?
Whoareyou
Hi all,
Just received my LG 42UH750V. I applied all the settings I wanted for the contrast, colour, etc. But each time I turn the tv off they reset to the factory settings of 100. I have checked and im in HOME mode not STORE mode. The cable settings seem to have remained now for a few hours. But the Amazon app and YouTube keep resetting.
Any ideas?
Cheers
