I have a LG 55UH615T SmartTV.
1. I setup a few scheduled recordings from the digital TV (via Guide),
2. I have connected a USB HDD to the TV and
3. I then set the TV to standby (i.e. I switch off the TV but the power to the TV is still on).
4. Also, I disabled the HDD Eco mode to ensure the HDD don't go to sleep.
However, the TV doesn't record when the TV is on standby mode. Can anybody tell me how I can record when the TV is on standby mode?
My biggest mistake i brought lg tv even i called the support in iraq they hired stupid people they even didn't know what I'm talking about all they care it's taking your money
Sent from my SM-N900 using Tapatalk
    • By atcronin
    • By Pranay Mokida
    • By Hoghton Jim
      Many thanks.
    • By Cody94549
    • By StefanosBand
