Netflix resolution info
By Nicola123
By Jonatan de la Torre Gómez
By dolbnya
By svsrama
Sriram.
By cptl
Any thoughts?
Rodrigo Costa
Before the latest update I could see if Netflix was actually running video in 4K just by pressing info on the remote control, now nothing happens when I click it, why? Can it be fixed? Any ideas? Thanks.
3 answers to this question
