Need info about webos
Hello guys i have a couple questions about webos because I'm kinda new user:
1. Where to find the latest version of webos firmware for my tv?
2. is it possible to download firmware offline on computer and flash it to tv just like android phone (for example).
3. Can we install webos app from out of the store?
Sincerely.
Hi irnote3,
1. I downloaded a remote control apps-- "lg tv plus" from Google play to remote my lg tv from mobile phone. And the apps automatically asking if any update. The apps will download to mobile first, then only install to the tv.
2. I don't think so can download without go to the store. I'm not sure are you facing the same problem as me, I can't go to lg store to update, until I saw an user use his 4g mobile network to connect to his tv to update. It's work to me.
And wish to solve your problem
