Multi-view - no option for 2 TV channels simultaneously
Hi all,
I recently bought a LG TV with webOS 3.0 and it's really cool. However, the thing that annoys me is that i can't see 2 channels simultaneously in multi-view, but only TV + another input (e.g. HDMI). I've read that the reason could be in the country setting (in my case, Italy). Is there any possible workaround that does not entail changing my position in the TV settings? That would make my local "on demand tv" app unusable.
Inviato dal mio Nexus 5 utilizzando Tapatalk
    • By DW1
    • By garamja
    • By hollean
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
