screen mirroring doesnt work
If you go to actions at bottom right of your laptop then click project,you should get a few options of how you want to mirror,select duplicate,now go to screenshare app on your tv,this should tell you your tv is now ready for connection,now on laptop select connect to wireless device,it should pick your lg tv up,once it's found it select the icon,it should say connecting & you should also get the same connecting to your laptop on your TV,as long as your laptop & TV are both on your laptop you shouldn't have any issues mirroring but as mentioned you must go into screenshare 1st before pressing any connect buttons,hope this helps.
    • By crct
    • By David Daul
    • By Horniak
    • By DWINKS49
    • By Batman
