    • By Mandx
    • By Citron2010
      Hi,  I have an LG 43UN71006LB with OS v4.50.53 (latest)
      I thought I'd test this on my TV and it works very well.  I've even set "routines" on Alexa so that saying "Alexa, BBC 1" is a shortcut for "Alex, change the channel on LGTV to 101" etc.
      Also tried:
      "Alexa, enable Sound Share on LGTV"  - "that command doesn't work on device LGTV"
      Anyone have any ideas?
    • By NickL
      Br,
      Nick
    • By Bob17821
      I have problems with one of my WebOS TVs which looks like a speed problem, but when I do a speed check on my iPhone from just a few feet away the connection speed looks fine.  Thanks,  Bob
    • By robp
      Is there any reason why I have to wait up to 5 minutes for "checking" to complete and "Internet connected". IPTV, YouTube etc will nnot load until this is complete
