I have lg uh850 and worked well until yesterday ( 2 jan ) .
Yesterday suddenly tv restarted and dont show anything after lg logo ! Just black screen .
I have pointer in my screen and remote just work the pointer ! I cant click with remote .
I search alot and know that yesterday ( 2 jan ) lg had some update !
I think about webos problems or updating problems !
Is anyone help me with this ?
    • By mean2
    • By atcronin
    • By PVD
    • By JRay
