- 1
Up load files and images
By Hasan Ghasabi-Oskoei
Can you help?
By Muser
By mahdi alborzi
I need to update this TV
Model : 55SJ850V-TA
Serial number : 707CGKWMJ215
ESN : LGTV20171=11001816919
VSN : 1F580793
Widevine: LGTV17CLGE002389488
By mahdialborzi
از درگاه وای فای بروزرسانی نمیشود پس نساز به فایل برای بروزرسانی با فلش مموری کارت دارم.
لطفا کمکم کن ید
By Kuriko
Hey, I have 3 NAS (DLNA) successfully connected to my OLED65C97LA since months and from one day to another all three have the same issue. So I must be a bug in LG TV? But I do not know what to do?
- I can click on all 3 DLNA and its open a choice box for "music" or "image and video".
- Click on all 3 DLNA for "music" and I get access to this DLNA and see my music files and can play it.
- Click on all 3 DLNA für "image and video" and I get now only a black screen. I can move the cursor and open menus, but DLNA is black.
Am I the only one with this problem?
RickB
Bought a new LG 65UH6030. How do I upload new files to my USB external drive LG tv folders hooked to my webOS tv? How do I transfer files between the same external drive and my LG tv's internial storage folders?
