From The Verge:
LG is putting all the software in its new fridge. At CES today, it announced a connected “smart refrigerator” that includes both the webOS operating system and integration with Amazon’s Alexa assistant. This means that the fridge can do everything from automatically adjust its power settings to order groceries with your voice.
 has a 29-inch front touchscreen with something called Instaview, a “door in door” that can turn translucent to show you the contents of your fridge. LG also touts its ability to look up recipes, play music, check the weather, and shop online. Instead of sticky notes, users can leave notes and tags on the front using webOS, and a “fresh tracker” can keep track of food expiration dates. Third-party integration with Alexa also means you can use voice commands instead of the touchscreen.
Watch the video and read more:
  • 5 years later...
Has anyone come across solving problems instruction for connecting LG refrigerators via WiFi? I have gone through all the pages and followed the whole sequence of steps to connect my LSFXC2496D using online manual (hope it's full not cutted version similar to paper book:
), but my Microtik router still does not see the refrigerator. Perhaps there is some advanced troubleshooting section for wireless devices?
