  • 4 months later...
    • By mahdi alborzi
      I need to update this TV
      Model : 55SJ850V-TA
      Serial number : 707CGKWMJ215
      ESN : LGTV20171=11001816919
      VSN : 1F580793
      Widevine: LGTV17CLGE002389488
    • By mahdialborzi
      از درگاه وای فای بروزرسانی نمی‌شود پس نساز به فایل برای بروزرسانی با فلش مموری کارت دارم.
      لطفا کمکم کن ید
    • By Kevin_Idaho
      Our LG TV was just updated with the latest software - before when the TV was turned on it was set to the previous input (one of the HDMIs).   Now it appears to be sent to the Home Dashboard and I have to manually change it to the desired HDMI input.    Does anyone know how to fix this?    Thanks!
    • By David J
      Hi all,
      My LG OLED55E7N just updated to firmware 06.00.25. I must have wronged the god of Google, because I fail to find any whatsnew. Anyone?
      Thx
    • By Nova1545
      I have a 55UH6150 LG Smart TV and was wonder if it was possible to update it to version WebOS 6. I have some apps I would like to install but sadly they are only avaible on the content store from WebOS 6+. Is it in anyway possible to update the SW for it?
      I know the page doesn't show WebOS 6 listed for it, but am curious if there is a way I can do it anyways
      Any information would be much appreciated
