Can't pause 4OD player app
Generally, I'm mightily impressed with the player apps on my new LG OLED55B6V, apart from an annoying issue with the 4OD player. The app works fine for navigating and selecting content, but once a selected programme starts playing I have no way of pausing it, forwarding or ending the programme other than by selecting another app. I've tried every button on the magic remote and even tried the mouse, but I have no control of the player once a programme starts playing. Is this a known issue and is there a fix on the way, or am I missing something.
Any thoughts?
    • By Jack1151
    • By wallyricks
    • By MNHL
    • By JamieG
    • By Puja aingh
      Dear LG TEAM,       Kindly update my content store because I can't find the HOTSTAR APP AND JIO CINEMA ZEE5 AND SONY LIV   THANK & REGARDS VIKASH SINGH
