LG Refrigerator age volume
By Danilo Peixoto Ferreira
I wish I could control the volume of my LG TV 65NANO96SNA (webOS 4.50.71) using Apple TV 4K 3rd Generation (tvOS 17.3) with HDMI CEC (Belkin AV10176bt2M-BLK cable). The Apple TV has it on Settings, however, the TV does not respond to it. Turn on/off works. Volume control only works with IR. Could we prepare an update to support and fix it?
By RCarlton
I have a 2 year old LG smart TV and A LG soundbar. Periodically the volume will drop way down and when I turn the TV off and on it restores to regular volume. TV or soundbar? Any ideas?
By PoeyYong Wong
I have this LG OLEDXXCXPTA TV with Sonos for over 2 years. Except in the beginning where I have some issue with volume control with Sonos, it has been working fine. Recently I am encountering problem controlling volume with LG remote for my Sonos Arc. The only way I could get it back to work is to reset the LG TV to initial setup like what I have done 2 years + ago to regain volume control back with a new setup.
However this time it seems to be different, I continue to lose volume control unexpectedly and I cannot see a trend. The latest being when I use the Netflix app to watch shows on my LG TV.
Any suggest to resolve this?
It is getting frustrating to keep resetting TV to initial setup so that I could use the remote for volume control.
By Harlock
Well it's more of a question, but if it's not possible then it's a request
When I change the volume the TV displays a + / - menu on the right, but it doesn't show what the current volume is. Sometimes when you start a video it seems too quiet, but that's not the volumes fault... so you crank it up and then the whole place explodes...
If it could display some kind of visual meter for volume, or simply a numerical value...
For some reason when connected to the bose soundbar there is a numerical value, but not on the switch, Home OS screens or firetv... all those are stuck with the simple +/- symbol. Is it possible to change this ?
