Hi Guys,
I found a code online to let twitch work with web os 3.0, but there is only 1 problem.
I can see the channels, but when I click on the game it just won't load.
It looks like it wants to open twitch in flash mode, but in the code I programmed it as HTML5 but it still doesn't work.
Who could help me?
twitchproject.zip
  • 3 weeks later...
  • 2 months later...
  • 5 months later...
  • 2 months later...
just checked the source, and it is using the depreciated APIv5, so this will need to be rewritten to use the new API.
Do you have a link for where you found the code ?
EDIT:
found it here:
also found this one:
might take a look at these this weekend
  • 3 years later...
there is no Twitch app for the LG webOS as far as i found out and there is nothing planed. I now use the Amazon Fire Tv Box with some kind of twitch app but it should work too with the Fire TV Stick or something like that.
    • By Justdontcare
      I have LG C2. I've been having problems with the twitch app for a few days now. It freezes streams for 5-10 seconds, the chat continues. I have 1gb/s internet and I tested Twitch on my phone, tablet and PC and it worki fine. I deleted twitch on tv and installed it again and still the same. Yt works fine on the TV, but there are problems with Twitch. I felt like throwing this TV out the window today. If LG can't handle a few stupid applications, it's probably time to go to the competition and never look back. Does anyone have any advice on how to prevent them from freezing or is it just the way webos is?
    • By sergiu gok
      I can't believe this is an issue to a smart tv (lg oled55bx3lb). I am watching twitch and after 5 mins the firework screen saver appears. Is there a workaround for this issue? Can't the software team resolve this issue?
    • By OLED55B7
      There is no option to select the desired resolution, the default resolution is often times unbearable (i have good internet -> 200+ Mbit/s..), this used to be possible in the discontinued game streams application. Please add this feature in the future, it would really make the app worth using! 🙂
    • By Pik Watcharee
      Dear LG, I really hope that LG WebOS can add on the Twitch apps ( link hidden, please login to view) . I sure it will boost up the LG tv market and sell. Thank you LG
    • By Unix3r
      any twitch app for webos 2.0  ?
