flash player or htm5 browser
Go to solution Solved by Alex,
  • Solution
This is correct, flash is not supported and is slowly phasing out.  Just do a search online and you'll see flash is no longer the way forward and content providers will need to update to HTML5.
    • By Jack1151
    • By mycop
      Greetings.
    • By wallyricks
    • By MNHL
    • By DeeDeee
