  • 1
Shahid application
Dears!
Kindly note that Shahid application is o e of the most application for the Arab World. It is the biggest Arabic Tv library. Can you please advise when the application will be available in line with Samsung and other Android systems??
Best regards
Ahmad
Sent from my iPhone using Tapatalk
    • By Junaid Ahmed
    • By Ganesh R
      Hi LG Team,
      Regards,
      Ganesh R
    • By Nishant singh
      Hi Team
    • Solution For That Pollution
    • By Gabor Monzak
      The LG Gallery is a very nice application, I use it many times, but unfortunately there are few classical paintings. Unfortunately, uploaded user images are represented by a variety of transitions and animations, which greatly worsens the artwork.
      It would be good if:
      - The number of factory-downloadable images would increase to multiple
      - Simply display user UHD images without any crossover animation (get the effect on and off)
      - It would be possible to play back-up images in random order.
